7.3 wont start
Old Mar 6, 2008 | 05:19 PM
bigbubba87's Avatar
bigbubba87
7.3 wont start
the head gaskets were bad on our 7.3 so i took it apart we had to replace the head on the passenger side it was cracked so we got new injectors and a return line kit i have it all installed i took the injector pump off but did it so the gear stayed in so i didnt get out of time i tried to start it and it wont even hit it just turns over. did i get it out of time somehow? or what else might be wrong with it Thanks Justin
Old Mar 6, 2008 | 06:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Did you bleed the air out of the injection system?
Are you getting any smoke out of the exhaust?
Did you put the wires on the IP in the correct locations?
Old Mar 7, 2008 | 02:22 PM
bigbubba87's Avatar
bigbubba87
i put all the wires on and bled the lines. well lastnight about 10:00 i got mad and decided to try and pull start it i pulled it about 2 miles and it fired up running rough so i brought it home and left it i went out today and started it and it runs fine but one injector line is leaking
Old Mar 7, 2008 | 05:09 PM
PLC7.3's Avatar
PLC7.3
Is it a steel line leaking....they leak above the steel cap nut or an oring and plastic cap they leak below the steel cap nut......
