Explains all the tailgaters and dirty looks from folks... What are some of the things I need to check in order to get them functioning?
Mike
The first thing I would look at is the switch itself, it's the pressure type.
Stepping on the brake pedal forces fluid into the switch...then...the brake lights are supposed to come on.
But the small hole in the threaded end of the switch where the fluid is forced into, easily gets clogged up with dirty brake fluid. When that happens, the switch is history.
The switch is either screwed into the master cylinder itself, or to a brass fitting that's screws into the master.
It has two male connectors on one end for the two wiring harness leads to plug into.
another thing to check after numberdummies suggestion is the connection at the back of the pickup. it is about a foot up along the frame towards the cab to make sure that is connected. use a tester to check the connection at the master cylindar. on of them should be hot. may have to have key on. have someone step on the brake and then test the other. it should come on also. if no, it's toast. if no juice to either my guess would be the fuse. are any of the lights in the back working. tail,turn.??? the light fixtures in the back are a body ground and if they are still original it may be a place to look also. as i have had this trouble in all my trucks at one time or another. good luck. Dutch
One way to know for sure if it is the switch is to connect the two wires on the switch together bypassing it. If the brake lights come on you know where the problem is. Uber simple. One solution to get rid of the problematic stuck switch is to replace it with one you munt under the dash that touches the brake arm. You can pick up a dome light style one for $15 make a mounting bracket and not have to worry again. I say a dome light style because it looks like one but it is meant for GM.
That's what I did. The old pressure type one on the master cylinder was busted, so I figured that upgrading to an electric switch type would be better, also because it is easily adjustable.
do u have any pictures of this new switch your speak of. im wiring my truck this week and need to get my brake lights working ..please take some if you don't already have some.. thank you ... you can also email me at guam05@adelphia.net if you like..
I had nothing but a left turn signal when I got my slick. I replaced the brake switch (it was like 8 bucks from rockauto.com) and now I have 1 brake light...Still no tail lights or RH turn signal, but I'm getting there! I haven't checked any wiring yet, but hopefully its just a bad fuse or something easy. I already replaced all of the bulbs...
Maybe check or replace the turn signal flasher to the right side, before you do that take it apart in theback and make sure the ground is grounding. very common problem in these old trucks, the switches have a body ground through the screws that hold it on. test the wires going to the light at the back end and see if the juice is getting to it,your brake light and turn signal are on the same wire. then test the wires coming out of the stearing column to make sure juice is going through. if not then it's a broken wire, fuse , or signalstat. few other things to do also but these are the most common ones. the can of worms gets bigger LOL. Dutch
Find majority of elect. issue results from a poor ground. Suggest taking continuity light and start at the taillights, believe poor ground on 1 will effect the other.
Well if the ground doesn't fix it look at the turn signal switch. If the flasher was bad you'd have no blinking at all. This is an attempt at writing the routing so bare with me...
Brake power runs out of the fuse block to the brake switch up to the turn signal switch then to the brake lights.
Turn signal power runs out of the fuse block to the flasher unit then to the turn signal switch which routes it to correct side.
The running lights and tail lights get their power directly from the headlight switch.
Now if you look at the link it should explain match what I wrote...
