60 wiper arm removal
Old Mar 6, 2008 | 01:32 PM
Dan Tenn's Avatar
Dan Tenn
I need some help getting the wiper arms off my 60 f-100. I can't see a set screw. Do I need to use a puller?
Old Mar 6, 2008 | 02:16 PM
jaye's Avatar
jaye
Not sure if your wiper arms are like mine (55) I just lift them up and pry them off, when you lift them up you are disengaging a tab on the base of the arm socket. Hope this helps. The first time I used a screw drive to apply some pressure.
Old Mar 7, 2008 | 05:16 AM
Col Flashman's Avatar
Col Flashman
They pull right off once you get the tip if a Flat Bladed screwdriver under them to Pop them up first.
Old Mar 7, 2008 | 06:08 AM
Walston's Avatar
Walston
There is a little spring clip that goes under the gear to hold the on. It goes along the body of the arm. Tilt the arm up and you should be able to see it. It usually lets you pull the arm off as long as the hold the arm up at an angle. I can post a picture this evening.
Old Mar 8, 2008 | 02:11 PM
Walston's Avatar
Walston
This is not a great picture, I couldn't get a clear photo that close up. However you can see the little clip that holds them on. This is the two styles I have seen on 57-60's.
