scanner code question
Old Mar 6, 2008 | 09:11 AM
bingo begone's Avatar
bingo begone
I have a '99 Expy EB with 105K. The dash light "Service Engine Soon" light came on, resulting in codes PO171 and 174, System too lean, Bank 1 & 2. Can anyone tell me what the fix is for this code? The light came on a day or so after i had the oil changed...any chance something got unplugged? The engine seems to be running fine, so far. Any ideas?
Old Mar 6, 2008 | 11:00 AM
pdqford's Avatar
pdqford
A number of posts on this pair of codes - they seem to say that something called a "PCV elbow" causes a vacuum leak, setting these codes. I'd check that first.
Old Mar 6, 2008 | 02:57 PM
buzzard's Avatar
buzzard
Try disconnecting the battery for 10-15 minutes to see if that clears the codes.
Old Mar 6, 2008 | 10:05 PM
mallen88's Avatar
mallen88
Check your oil cap. If they forgot to put it back on when you got your oil changed that will give you those codes too. Had this happen.
