57 hood
Old Mar 5, 2008 | 09:44 PM
Bob at warsaw's Avatar
Bob at warsaw
57 hood
Hi group
Was the 57 hood onley made for one year, and
all others are diffrent styles?
Thanks Bob
Old Mar 5, 2008 | 11:33 PM
idaho211's Avatar
idaho211
The 57 and 58 ford hood are the same from f-100 to at least f-500. I had a f-500 hood that fit fine. I believe the larger trucks had a wider hood.
Old Mar 5, 2008 | 11:43 PM
2many56s's Avatar
2many56s
Like idaho said it was used on all 57-58 trucks. It was continued on 1959 and 1960 on the on the F-700 and up trucks.
Old Mar 6, 2008 | 03:56 PM
Col Flashman's Avatar
Col Flashman
They only difference body wise between the '57s & '58s were the Badging & the Grilles.
Old Mar 6, 2008 | 06:26 PM
Bob at warsaw
Hi Group
So all is saying that a 57 that has single headlamps, will swap
with a 58-60 with duel headlamps?????
Thanks Bob
Old Mar 6, 2008 | 07:27 PM
Col Flashman
No, the '57-'58 F/M-series trucks will swap perfectly between themselves & '59-'60 F/M-series trucks will swap perfectly between themselves, But not between the two Sets of Year Models.
The '57-'58s F/M-series trucks have the ROUND Turn Signals, the Wider Lower Fender section for the Round T/S, Taller Grille, Narrower Grille/Vallance set-up & Shallow Peak Hood.
The '59-'60s F/M-series trucks have the RECTANGULAR Turn Signals, Narrower Lower Fenders for the Rectangular T/S, Shorter Grille, Wider Grille/Vallance set-up & Progresively Deeper Peak & Taller Upper Sections on the Hoods.
Because of these Body changes between year Sets, if one wishes to incorporate singular Front Cap parts from either of the 2 Year Sets, one has a Great deal of Body work ahead of themselves to do, because it will be necessary to either Fill-in the Gaps between the Sheet Metal or get rid of Sheet Metal no longer needed from the swap.
Plus the Peaks on the '59-'60 Hood are To Deep for a Proper fit w/ the '57-'58 Grilles, as they will not close or if one manages to force the fit, they'll Rub horridly.
The only way to avoid this is either to leave your truck the way it came out of the Factory or Swap-out the Complete Front Cap between the 2 Year Sets.
Old Mar 6, 2008 | 07:35 PM
Bob at warsaw
Smile
Hi Col
Now that makes since to me, you are a gueinus
Thanks Bob
Old Mar 6, 2008 | 07:48 PM
Col Flashman
Thank'ee kindly, B.@.W.!
I've come to find out here @ FTE, that I either inspire compliments such as yours or that for the most part, that some believe I'm far to Opinionated for my own good & that my Point-of-View is rather frowned upon by Certain members Comfort.
Now don't get me wrong about FTE & its members, it's the Greatest place one is able to find the information that you need for your project & resources to acquire parts!
Old Mar 6, 2008 | 07:56 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Here,here!LOL
