fuel leak
Old Mar 5, 2008 | 09:24 PM
jjacobs5623's Avatar
jjacobs5623
fuel leak
Ok,the problem I am having, when I start my truck up, fuel leaks big time from what I think is the fuel pump. It is an 82 250 with the 302, carb. The fuel looks like it is leaking from the bottom of the pump, but it is hard to tell as it is also dripping off of the oil filter. My question is - should I replace the pump or the lines or both? Thanks in advacne for any help.
jonathan
Old Mar 5, 2008 | 10:03 PM
Franklin2's Avatar
Franklin2
Replace the pump and the short piece of rubber hose.
Old Mar 6, 2008 | 01:04 PM
doug1222556's Avatar
doug1222556
It may not be the pump. It sounds like the pump is making good pressure and you have a leak in the line. The gas is naturally going to find the bottom of the pump, because the leaky line is attached to it. You may just have a leak in the line to the carb.
Old Mar 6, 2008 | 02:00 PM
jjacobs5623
cool thanks for the info, I'll check it this weekend and hopefully fix it!
j
