M-block cylinder heads info
I am thinking 9 to 1 on pistons or 9.5 to 1. I want the overall close to 10 to 1. I did however find more cast #s on the D1AE-A1C heads. Looks like a 26 or 28 stamped in corner both inside corner of valve cover and on the underneath far outside corner of the milled side? and a 2M5 in the middle on spring side. I believe they are 2v? The valves are staggard from each other?
The TMI pistons are slightly taller above the pin. He did this to reduce the distance from the top of the piston to the deck.
M-Block
Cool. Makes total since. I believe that D1AE-A1C are Australian 71 Cleveland Heads? Certainly 2V heads. My machinist will be giving me confirmation on the chamber cc size this afternoon or evening. Having him put stainless valves and quality springs along with maching to make them adjustable. I will be calling TMEYER. Thanks
Sorry guys. Been out of the loop for a while. I am planning a 400cid build for my 79 f250 4wd and I have come across some D1AE-A1C casting numbers. I would like to know if these interchange with the M-Block and would they be usefull for a low to mid range tork over the stock 79 heads that I already have? Not exactly sure about them or their value? I can always use some helpful knowledge
we put a pair of D1AE-A1C heads off a 335 family (CI,?), on a 1977 400 in a F250 some years ago and they were/are fine, still going. The Combustion Chambers were cc'd but I have forgotten the amount; although, I remember them being smaller and worrying about a high compression. Pushing ten to one. Thanks for the consideration, Dan
HEADS Investigation
Hey Ford Monsters,
it is very good to see other experimenters working on castings versus chamber volume. If we ever get back to home bench it would be helpful to get a listing of various CC'ed heads to their actual casting numbers and tolerances within groups. After Knowledge is POWER.
Should be here sooner, Dan
C and M heads
I have a set of all three, 4 bbl C, 2 bbl C, and the 2 bbl M/400. Actually there are only 2 bbl size M/400 OEM's.
While the chamber sizes vary a little on the M's they are all essentially the same, bolt up like the C's.
The difference is in the exaust port. Just downwind of the exaust quide in the roof of the port is a water passage that crosses it. Its not very large, like the egr hump, but it does not allow much grinding in that area, which I think is important in air flow. It looks very similar to the GT40 "P" heads. There are cutaway views of that head (dont have a linkey though). It clearly shows the problem with grinding in the "P" head. Somewhere I have seen a cutaway of the M/400 head, dont recall where I saw it or have a link for that either .
Thanks for the info and much appreciated. I have my machinist doing the final assembly on the heads. He made them so they are adjustable with chevy roller tip rockers and some grind work. Bored .030 over and TMeyer custom pistons. Along with a variety of other machining. Engine is speculated to put out around a modest 320 to 350 horses but should have excellent tork in the upper 400s range. We tried to keep the compression down as close to 9 to 1 and so far as it is still premature. We figure around 9:47 to 1 so far. Thanks
#28
I use the chevy(454) roller rocker tip with 1.7 ratio compare to 1.73 from ford. Aussie head with TMeyer piston to get 9.5:1 comp ratio. The block was deck and the head were shave just to be straight. The zero deck piston past the block by 0.07. I call tim and said to don't worry if it's less than 0.15. i guess my comp ratio will be higher than 9.5.
The guy who rebuilt my head said to used soldering wire(for copper) and to put in the spark plug hole to get it crush between to piston and valve for clearance. by turning the engine by hand. I never did it but if someone have done it i would be greately appreciated.
#29
heard/read about it. Good practice if you are starting to squeeze up the clearances and raising compression and not sure about tolerances, basic engine rebuilding practices. Just like using plastigauge to check main bearing clearances. High compression and mad high lift cam probably more relevant than proven just better than standard components.
#30
More data for the cylinder head registry
This is from one set of heads I have:
D1AE-CB casting number. This is on the underside of the head.
Date code 1F2, top of head, under valve cover.
Combustion chamber volume as measured (two chambers): 79.5cc
"2" on upper corner of head.
No huge obstruction in the exhaust port.
I presume they are from a 400 because of the large chambers.
