wiring diagram
Old Mar 5, 2008 | 08:15 PM
tbirdage's Avatar
tbirdage
wiring diagram
Can somebody point me to a wiring diagram for my '02? I have a short somewhere that's blowing my #17 (ext lights) fuse. Thanks
Old Mar 5, 2008 | 09:00 PM
F350-6's Avatar
F350-6
If no one else helps, I might have one on my work computer. I'll look tomorrow.
Old Mar 5, 2008 | 09:03 PM
tbirdage's Avatar
tbirdage
Thank you. What if I get a Chilton's manual? Do they have a good one there?
Old Mar 5, 2008 | 09:35 PM
F350-6's Avatar
F350-6
If you want the best info a Ford Service DVD will give you better info. I got mine for free when I bought a used truck for work. The wiring diagram part is screwed up and only works every once in a while, so when I look at something I try and save the info in my computer. The cheapest place I've found that advertises the new manuals is http://www.4door.com/manuals/ford/ford_dvd.html. I can't speak for their authenticity, but I have heard that some of the manuals purchased off ebay require you to change the date on your computer to the year of the truck for them to work.
The DVD will give you the same thing the Ford tech's use, including trouble codes and diagnoistic methods in addition to the standard remove and replace procedures.
Old Mar 6, 2008 | 01:17 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I will check in the morning and if nobody has posted the diagram I will see if I can paste it over from my dvd.
Old Mar 6, 2008 | 12:19 PM
FordTruckNoob's Avatar
FordTruckNoob
I have the wiring diagrams for the '00 model which should not be all that different from yours. Let me dig around and post them.
EDIT: Here are the diagrams. Let me know if you need any others.
Diagram 13-22
Diagram 34-1
Old Mar 6, 2008 | 12:26 PM
F350-6's Avatar
F350-6
This is from an 02. Hope it helps
File Type: pdf
File Type: pdf
Old Mar 6, 2008 | 12:57 PM
F250_'s Avatar
F250_
If you still need more than what's been offered here, send me your email address and I can shoot a collection of drawins to you from the For Shop DVD.
Old Mar 6, 2008 | 03:13 PM
tbirdage's Avatar
tbirdage
Y'all rock! Thanks again
Old Mar 6, 2008 | 07:54 PM
tbirdage's Avatar
tbirdage
If y'all will look at drawing #1, I need to know where the connector (S107) (left side of page in the middle of the lamps) It is the front parking lamp harness connector. I need to disconnect that and try to isolate my short. Those wires are so buried in there, I don't think I'll ever find it going in blind without tearing everything apart. Thanks
Edit: Sorry, drawing 1 from post #7
Trent Racer
Aug 21, 2015 05:35 PM
lovs2fly
Feb 2, 2012 12:35 PM
Zack Dekker
Sep 26, 2010 08:33 PM
rblaine9000
Feb 18, 2009 05:06 PM
greghoffmann
May 14, 2001 08:04 PM
