running ruff
Old Feb 6, 2002 | 07:06 PM
jevanof's Avatar
jevanof
running ruff
My 79 Ford F150 has a 351M and its running ruff, Its hard to start when its cold. and doesnt seem to have the power that is did before. Put still runs. I changed the plugs, wires, cap and rotor. Any tips?
Old Feb 6, 2002 | 08:34 PM
thelonerangerxlt's Avatar
thelonerangerxlt
running ruff
[updated:LAST EDITED ON 06-Feb-02 AT 09:36 PM (EST)]The next (cheapest) thing that I would check, is the screw-in fuel filter attached to the carb. On these old trucks, rust can clog them pretty quickly.
EDIT: OK, I noticed you have a 79 (with a catalytic converter). If this was clogging up, it would cause the symptoms you describe.
Old Feb 6, 2002 | 08:47 PM
jevanof's Avatar
jevanof
running ruff
sory no cats, I will check the fuel lines and filters.
Old Feb 7, 2002 | 12:20 AM
xyfalcon500's Avatar
xyfalcon500
running ruff
my 351C was runnin rough and i changed the plugs, leads, cap AND fixed a vacuum leak... but what actually fixed it was a new ignition coil, now it runs perfectly.
Old Feb 9, 2002 | 04:47 PM
spaul78's Avatar
spaul78
running ruff
had a 351C and was running rough and cutting out about 2,000 rpm... desconted the vac advace and runnning perfect since!
steve
Old Feb 18, 2002 | 06:04 PM
jevanof's Avatar
jevanof
running ruff
to the left of the carb on the intake manifold of my 1979 F150 (351M)there is a plate the bolts to the intake that goes to the EGR valve and also the choke line coil through the plate as well. Mine a rottet out, and the motor runs very ruff. So here I am, I know what the problem is, I took the old part and the part store dident know what is is and dident bilieve me whene I told there where is goes on the truck, I went to a ford dealership and they told me that the part is out of production and I have to find a aftermarked part. I called every part store in the phone book and knowbody had any idea what I was talking about considering that I dont know what the part is. But I do have a part number (DSAZ9C869A) If anyone could help me I would be very gratfull.
Joe
Old Feb 18, 2002 | 07:42 PM
Made in the 70s's Avatar
Made in the 70s
running ruff
Patrick714
May 30, 2014 05:23 AM
jbarefoot
Flathead V8 & Flathead 6
Jun 15, 2011 11:36 PM
got2befast
Sep 25, 2010 08:06 AM
Dbailey
13
May 31, 2010 11:55 AM
xavetarx
Feb 6, 2002 07:59 PM
