chip problem
Old Mar 5, 2008 | 01:03 AM
linkford's Avatar
linkford
chip problem
i have recently baught an edge juice with attitude from a buddy, cheap.. i thought it would be cheaper than buying guages. when i hooked up this chip my modified 10k mod would not work.. is there any way to get my 10k mod to work with the edge box monitor... and i also plan on buying a dp tuner in the future and was wondering if they would work together???
thanx
Old Mar 5, 2008 | 03:54 AM
imelmo's Avatar
imelmo
Don't know about the Edge and your 10k, but you won't need the 10k with any proper chip.
Old Mar 5, 2008 | 07:20 AM
UP_There's Avatar
UP_There
Once you get the DP Tuner installed, it won't work with either of those, although I am not sure with pulling codes with the edge. Jody told me my superchip will still be able to pull codes once I get my DP! But you won't even WANT the edge......the DP will completely blow it away!!!
Old Mar 5, 2008 | 10:10 AM
linkford's Avatar
linkford
i was just using the readout display for the boost and egt..
Old Mar 5, 2008 | 10:19 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If you do go with DP, you will need an OBA. Then you will not get a true boost reading with the Edge display. The Edge uses the reading that the PCM sees. The PCM will not see the real boost. I love my piller gauges from Diesel Manor. I would think watching numbers flying by would be kind of hard to read.
Old Mar 5, 2008 | 10:59 AM
linkford's Avatar
linkford
ill look into getting guages..thanks for the info...this will get me by till i get my DP.
