Rebuild time
Old Mar 4, 2008 | 07:32 PM
hotrod 250's Avatar
hotrod 250
Question Rebuild time
Hello all, I have a few ?s . Has anyone rebuilt their own 4r100 trans. I was looking for a list of sorts on the parts, more specifically thebrand of clutches,steels and bands that were used. Even better would be what are the gurus like John Wood or Brian at bts using. I have cofidence in my ability but i dont know whats the best parts to use.I have a 03 f-250 with 5" ,DP ,gauges ,fuel preassure mod and meth/water injection and it really does run strong. I have no problem hitting 32-35# of boost ant the trans is starting to slip.Also whats everyones thought on the 6.0 converter.Ive got to do something quick and funds are tight,i will be getting a ATSG guide for all the torque specs just want the best trans for the money. Thanks
Old Mar 6, 2008 | 09:49 PM
blue beast's Avatar
blue beast
http://www.transmissionpartsusa.com/...ive_s/9154.htm http://www.becontrols.com/tech/ch2aodefund.htm
http://www.lincolnsonline.com/tech/00080.html
A trannny temp gauge is worth the money even if they costed $150.00 since
they can help prevent the tranny from breaking $1000.00+ I prefer a digital
one since the response is quick and you can alter your driving to let it cool down.
You should see the numbers climb while waiting in the drive thru!! Doing that little
trick where you let the motor hold you on a hill instead of the brakes makes it sky
rocket up like crazy " Don't do it!!" When you swap the tranny making sure all the
cooling lines and the cooler is super clean will prevent a repeat and is the number
one mistake most folks make. Pressure washing the cooler I mean blasting water
through the lines and then follow that with denatured alcohol and about 80 psi of
air(no flames around!!) Then at least 2 quarts of cheap fluid and catching it in a
clear bottle so you can inspect it for crap. Your rebuilding area should be clean as
possible and you should try to do it all in one day if possible since leaving it open
could allow bugs and dirt to find a home in your new tranny!!
