supercab lift
Old Mar 3, 2008 | 11:39 PM
Murph2006's Avatar
Murph2006
supercab lift
i have a 79 supercab, and as you know the half ton sc comes with leaf springs in the front. I bought a set of 3 inch lift blocks, but a guy told me that its not a good idea to use the blocks on the front because they would cause my front drive shaft to break when i use 4wd. He also told me that i was taking a chance on them coming out when stopping. Anyone used them and is there any truth to those comments? thanks
Old Mar 4, 2008 | 12:19 AM
masterbeavis's Avatar
masterbeavis
DO NOT USE BLOCKS IN THE FRONT OF YOUR TRUCK!!!! What would happen if you were to hit a big bump? Your blocks will spit out is what. Do not do it. Buy some lift springs, have your springs re-arched, anything except lift blocks in the front of your truck. Yes big rigs have lift blocks, but they are engineered that way, and are prone to not ever fail. Just becasue it works at the mud pit, or on a big rig does not mean that it will work for you, or that its safe.
Old Mar 4, 2008 | 12:53 AM
Murph2006's Avatar
Murph2006
ok just making sure thanks
Old Mar 4, 2008 | 01:30 AM
jhooch's Avatar
jhooch
Not to mention, front lift blocks are illegal in most states.
Old Mar 4, 2008 | 05:14 AM
JMarkle's Avatar
JMarkle
I have a 78 Supercab. Getting ready to drop a 460 into it, after trashing my third 351M. If you have any luck lifting it, please let me know. I have looked around for suspension kits for these old SC's, but can't seem to find anything. Thanks.
Old Mar 4, 2008 | 07:25 AM
jimlj's Avatar
jimlj
I had my springs rearched and added one leaf. It got me 2 1/2 inches AFTER adding my Cummins. I'd guess you will have even more with your engine.
Old Mar 4, 2008 | 09:34 AM
shoot4fun's Avatar
shoot4fun
Don't beat around the bush MB. Go ahead and say what's on your mind... No really! Don't *****foot here. Tell us what you really think...
I know, I know. I've seen guys try it, usually with disasterous results. Don't blame you for trying to stress the point. Just had to make fun.
Brad
Old Mar 4, 2008 | 03:37 PM
fdude64's Avatar
fdude64
i had 2" blocks all the way around on a 78 f250 i had they worked fine and i am hard on trucks. i had over size u bolts made up at a local spring shop and made sure they were installed "right". no problems but that is just my experience.
Old Mar 5, 2008 | 10:24 AM
79schaefer's Avatar
79schaefer
I've had 1" blocks up front on my truck and spit them out twice. DO NOT DO IT. This was 15 years ago before it was illegal here in PA.
Steve S.
To many to list.
Old Mar 5, 2008 | 03:42 PM
fdude64's Avatar
fdude64
my blocks had the locating pins on them but they were on my truck for about 5yrs till i sold it
Old Mar 5, 2008 | 06:52 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
78/9 F-250 lift kits will work. Also 99-04 superduty front springs will work
Old Mar 5, 2008 | 08:10 PM
RCrawler's Avatar
RCrawler
I'm not condoning the use of front lift blocks, but these have been on my pickup for almost 250K miles of hard driving, towing, hauling, and a few trails. Never spit one out, never came loose.
Jason
Old Mar 6, 2008 | 01:15 PM
plowpusher's Avatar
plowpusher
You can buy an add a leaf set from JC Whitney for about 79 bucks gave my truck about 2 inches. I also used new u-bolts I got from LMC (stock length)
