I got my Edge 2 weeks ago and finally got time to program it to Level 2 with 87 octane. Am I suppose to Bump up the timing +1 when using 89, and +2 when using 91 octane? One more question is Level 3 (performance mode) meant for 91 octane without any adjustment with timing?
I have an unmodified 2004 F-150 5.4l 4x4 Screw with 6500 miles and around 1800-2000 feet above sea level. Just programing it to level 2 and it gave this truck the performance I was expecting when I drove it off the dealer lot 3 years ago. I expected 'get up and go' when driving off the lot. Once in awhile it would stall at a long red light. Then I had Ford fix it, they flashed the PCM and it was even more gutless ever sense. But now I find myself liking this truck again and my thoughts of ridding myself of the "past" gutless truck are now gone. I'm just worried that I am not properly informed about octane vs. timing using the Edge.
You are correct about the timing on level 2. Level 2 is meant for 87. In Level 2, if you to 89 timing goes +1, 91 +2, and so on. Level 3 is meant for 91 (or higher) so in level 3 there is no timing adjustment if you are using 91 octane. If you use 93 octane in level 3 timing goes +1. Hope this helps.
How big of an altitude change does the timing change. Meaning if im at 2000 feet at home and want to travel and I end up at sea level, will I receive ping or detonation?
How do you detect ping and detonation? If I use the lightning software to log and graph, how do I tell when pinging or detonation occurs?
The MAP sensor should pick up the difference in altitude (atmospheric pressure). Going from low pressure to high pressure shouldn't hurt much in a fuel injected tune. Worst case I can think of is your going to run a bit leaner, but the o2 sensors should pick up on it and add more fuel to compensate.
