Trans service on 07
Old 03-03-2008, 09:32 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
Trans service on 07
What is the trans service scheldue for my 07 F150 4x4 with the 5.4l? I cant seem to find anything in the manual other than if you have the TorqShift in the diesel.
Old 03-03-2008, 09:34 PM
Ford Fx4's Avatar
Ford Fx4
Ford Fx4 is offline
I believe it is every 30,000 miles.
Old 03-03-2008, 09:38 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
shouldnt that be in the manual though?
Old 03-04-2008, 06:51 AM
Deluxe05's Avatar
Deluxe05
Deluxe05 is offline
Per the '2007 Model Year Scheduled Maintenance Guide':
Every 15,000 miles - Inspect automatic transmission fluid level, if equipped with dipstick.
Every 30,000 miles - Change automatic transmission fluid on vehicles equipped with the Torqshift transmission. Replace the remote filter element on the vehicles equipped with the Torqshift transmission. Inspect automatic transmission/transaxle fluid level on all other vehicles, if equipped with dipstick. Consult your dealer for your particular requirements.
Old 03-04-2008, 09:53 AM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
They way I read that is it does not apply to my transmission other than checking the fluid.
Old 03-04-2008, 10:16 AM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
Yea, I guess that's right, but my dealership insists that they flush mine every 30K!!! I let them do it the first time, but not since. I have almost 90K, but I will drop the pan once the temps warm up and change the filter and fluid myself.
Old 03-04-2008, 07:21 PM
Twinsdad98's Avatar
Twinsdad98
Ok, so I pulled out the scheduled maintenance guide that came with my 04 F150. According to Ford, for the 30K service:
Change automatic transmission fluid on all vehicles equipped with 4R100. Inspect automatic transmission/transaxle fluid level on all other vehicles, if equipped with a dipstick.
So, for my 04, that means every 30K, I'm to change the fluid.
Old 03-04-2008, 09:18 PM
Bill06FX4's Avatar
Bill06FX4
Bill06FX4 is offline
Dumb question, but how do I know if I have a torqshift transmission? I have a 2006 SCrew FX4...
Old 03-04-2008, 09:31 PM
wreedZ71's Avatar
wreedZ71
wreedZ71 is offline
Torqshift is diesel only.
Old 03-05-2008, 12:31 AM
Bill06FX4's Avatar
Bill06FX4
Okay, I misread above. What transmission do I have, and how often do I need to change the transmission? I'm coming from Jeeps and Dodges where there is no requirement to change the tranny fluid unless used for severe duty. Thanks...
Old 03-05-2008, 09:46 AM
Tom's Avatar
Tom
Tom is offline
Nope.
The 4R100 is the tranny they put in the super duty, and the old F150 lightnings.
You have the 4R75E tranny, and it is supposedly good for 100k miles.
THEY DO NOT PUT A TORQSHIFT OR 4R100 IN F150S!!!!
Ford recommends the same, supposedly the fluid is good for the life of the tranny. I personally disagree, and like to do it every 50-60k miles, but every 30k is NOT necessary!
Old 03-05-2008, 12:13 PM
Bill06FX4's Avatar
Bill06FX4
Originally Posted by Crazy001
Nope.
Thanks! That is what I was trying to figure out. I've always changed the fluid at about 50-60K miles on my Jeeps and Dodges, so I will do the same on the Ford...
Old 03-29-2008, 09:48 PM
f15097's Avatar
f15097
f15097 is offline
Hello Tom I have searched the forums and found your message and it seems you might know the answer to my question. I am trying to Identify my transmission. I have a 1997 f 150 4wd 4.6l Romeo. I have taken two set of numbers off the side. One is Rff7ap7008-aa the other is 7a040-BA Thanks for any help.
Old 03-29-2008, 10:00 PM
Tom's Avatar
Tom
Tom is offline
I'm not sure about those numbers, but your truck should have the 4R70W transmission...I believe that's the only one they used from '97-2003.
Old 03-29-2008, 10:29 PM
f15097's Avatar
f15097
f15097 is offline
Thanks so much. I believe i am having converter shutter problems. I am going to try and and change the fluid and put the anti shudder additive in it and hope for the best.
Quick Reply: Trans service on 07
