Hard Starting '91 Explorer
Old Mar 3, 2008 | 05:55 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Recently I have been having trouble with my wife's 91 Explorer 4.0 5-Speed not wanting to start when warm. I pulled the codes and it has code 42. This means that O2 sensor voltage is too high, meaning a rich condition. I know that when a motor is running rich the oil coating the cylinder walls can be washed away and theoretically cause hard starting, especially when the motor is warm. What do you guys think?
Old Mar 3, 2008 | 06:03 PM
4.0 Beast's Avatar
4.0 Beast
Common on first gens is an intake leak. I know, i had one with the same problem. This could expand when the engine is hot. This would in turn cause the fuel mixture to be rich in turn causing the o2 sensor to report high voltage. What condition is the engine in?
Sounds a little simpler than that though. Have you checked the starter, solenoid switch, battery cables, and battery?
Old Mar 3, 2008 | 06:13 PM
1994 F250: 351, C6
First off, thanks for the advice. The engine is in pretty good shape, only 125,000 miles, and it was pretty well taken care of. I have also replaced the, alternator, starter, solenoid switch, batter cables, and battery all in the last 8 months, isn't great how everything goes wrong at once? They are all still good.
It looks like I will have to check for an intake leak. Do you mean a leak in the gasket, or a crack in the manifold itself. God, I hope it is not a crack in the damn manifold.
Old Mar 3, 2008 | 06:17 PM
4.0 Beast's Avatar
4.0 Beast
No problem Well, I dont want you to start working on it based solely on my advice, although it is damn flattering hehehe. Anyway, i mean a leak in the gasket. Your manifold itself is not likely cracked, although it is possible, mine wasnt, just a leaky gasket. Have you checked everything to do with the fuel side? Fuel filter, fuel pump, fuel pressure regulator, fuel injectors? All can cause a hard start and will run the engine rich if faulty.
Old Mar 3, 2008 | 06:21 PM
4.0 Beast's Avatar
4.0 Beast
Oh yea, 1 more thing. How are the plugs and wires?
Old Mar 3, 2008 | 06:30 PM
1994 F250: 351, C6
Plugs and wires are good, about 8 months old as well. I did a pretty extensive electrical tune-up on this thing over the summer. Fuel filter was changed about a year ago. As for the fuel pump, pressure regulator, and injectors, I have no idea.
ldfry001
Sep 14, 2013 09:51 AM
lemonshindig
Aug 28, 2010 11:22 AM
Kongslibakken
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 24, 2008 07:35 PM
bigzero
Mar 11, 2004 09:21 AM
94156
May 23, 2003 02:45 PM
