1978 - 1996 Big Bronco
Computer test port question?
Old Mar 3, 2008 | 10:54 AM
mikeberman04's Avatar
mikeberman04
do the '88s (mine is the 5.8 EB edition) have the OBD2 test ports, or is she a little old for that?
Old Mar 3, 2008 | 11:54 AM
jb1390's Avatar
jb1390
obdII came out in 96, late 95 for most models. I think you can jump two prongs together to read the troule codes using a paper clip or short piece of wire, but I don't remember which prongs.
Old Mar 4, 2008 | 09:08 AM
mprice's Avatar
mprice
Here's what you need:
http://www.amazon.com/Equus-3145-For.../dp/B000EW0KHW
You can find the paper clip method by searching, but I guess I'm too ADD for that. The scanner will pull all three code types plus cycle all the actuators. I keep mine in the glove box.
Calvin
Old Mar 4, 2008 | 02:17 PM
b4hntn's Avatar
b4hntn
That is the exact one I have....it is wonderful.
Old Mar 12, 2008 | 12:54 AM
alext33's Avatar
alext33
hay guy i have a question on my 95 bronco. how do i read the codes in the instruction manual it says that sum years are 3 or 2 digit code or is it sumthing else.
Old Mar 12, 2008 | 05:00 AM
b4hntn's Avatar
b4hntn
My 94 codes are three digit EEC-IV system.
It changed to obdII on some model in 95 and 96 so an obdII code reader might be needed if yours has it.
Old Mar 12, 2008 | 09:16 AM
Bimmerboy1989's Avatar
Bimmerboy1989
If it's OBDII then the diagnostic port is under the dash. If it's OBDI then the diagnostic port is under the hood by the drivers fender near the relays.
Old Mar 12, 2008 | 09:06 PM
alext33's Avatar
alext33
its under the hood thanks guys
