pulled a code or 2
Old Mar 3, 2008 | 09:35 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Talking pulled a code or 2
I haven't checked to see which one it is for sure yet, but I've got a pretty good idea. Full throttle up a steep grade, rollin' the coal... I guess it's time to look into getting a 17degree HPOP! SHe sure does move though. Happened 4 times in the last week.
Old Mar 3, 2008 | 05:34 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I guess you are thinking it's the ICP code....but it sounds more like overboost to me.
Old Mar 4, 2008 | 10:02 AM
Fullcrew7.3
I haven't had a chance to check and my boost guage only goes to 20 psi. I can extrapolate up to around 30psi, but it's not marked. She choked the one time it came on, so that's why I was thinking oil.
Old Mar 4, 2008 | 09:20 PM
cookie88's Avatar
cookie88
FTE Emeritus
When the HPOP isn't keeping up it will nose over pretty hard and start blowing smoke, after it normally would have cleared.
If you can push 30 PSI without a boost fooler of some sort it is definitely an overboost code that is tripping the light.
