Fuel Filter Change
Old Mar 2, 2008 | 07:39 PM
rockford04's Avatar
rockford04
Question Fuel Filter Change
Can I change my fuel filters (2005 6.0L) with a full tank? Every thing I read says to let it drain until it stops.
MeyerzF350's Avatar
MeyerzF350
Yes. It had no effect when I changed mine.
Old Mar 2, 2008 | 07:43 PM
cbirdman's Avatar
cbirdman
Yes you can do it. The filter on the frame rail will drain for about 20 seconds or so. Just get a old coffee can and drain into the can. You will get about 2 inches in the bottom of the can. Have fun its a little messy!
Old Mar 2, 2008 | 07:44 PM
UGA33's Avatar
UGA33
Yes. Last time i did mine i jacked the driver side front end up and pulled the drain plug. It drained for 15 sec then stopped. After that, a tiny little amount of fuel came out when the filter was pulled
Old Mar 2, 2008 | 08:20 PM
rockford04's Avatar
rockford04
Thanks guys. I just finished with the fuel filter change. Not such a bad deal. Thanks again!!
