SOMETIMES, when i start my 2001 F150 Screw, the speedo and tach needles spin all the way to the right and then bounce back (tach to 800 or so and speedo to zero). this only happens sometimes.
why?
does this occur because it's supposed to tell us low voltage, or it's a gremlin?
i have the original battery....half of me says to replace it soon so it doesn't leave me stranded.
I got a duralast redtop from autozone. I had my doubts when I bought but it works just as well as the original, even when it's zero out. I think it ran about 70 something. I was going to get a optima but after all the problems the guys in the lincoln forums have with them I passed.
thanks guys....LAST question....should i bother programming back to stock before pulling the battery? then reprogram after installing?
wasn't sure how it will work since i use the hypertech to change the WOT shifting.
Consumer Reports says the Napa 8465 is the best....
but many sites list three different sizes for my truck....
it won't let me edit my post, even though it's recent.
I read the manual and it says Group 59 and then a Group 65 for the heavy duty, which i plan on getting....hope it actually does fit!!!
well, i replaced the MC BXT59 with a Megatron Plus MTP65.
cranked right up, no gauge sweep.
but as always, something has to go wrong.
broke the hold down bolt, will have to drill when i have time in a month or two. heavy a$$ battery and no offroading, i think i should be fine.
one other thing, the OEM battery cover didn't fit back on....either it's only designed to cover MC batteries or i just didn't try hard enough.
