hooking upcigarette lighter?
Old Mar 2, 2008 | 07:19 PM
86F150302's Avatar
86F150302
Went to junkyard and got a ash tray with cigarette lighter for $2.66 and now need to know how to hook up the lighter to work.
Is something supposed to hook into the middle of it? Whats this wire? Ground? Power?
Old Mar 2, 2008 | 07:26 PM
klxstiffler's Avatar
klxstiffler
the middle is power and the outer sleeve with the wire you have on there already is ground. usually there is a special connecter that snaps over that stud.
Old Mar 2, 2008 | 07:27 PM
ri_truck_guy's Avatar
ri_truck_guy
Look for a yellow/blue wire with a small rubber boot on it under the center of your dash. The boot will go over the stud in the center of the lighter.
Old Mar 2, 2008 | 07:49 PM
86F150302's Avatar
86F150302
ok thanks. What if I cant find the boot? Can I get one from somewhere?
Old Mar 2, 2008 | 08:24 PM
Franklin2's Avatar
Franklin2
Go back to the junkyard.
Old Mar 2, 2008 | 08:36 PM
86F150302's Avatar
86F150302
damnit! lol
I getto rigged up a power wire and connected it to my battery and grounded the ground wire and it worked.
Is there a way I can splice into a power wire to make another one going to the cig lighter?
I didnt even see a yellow/blue wire.
Old Mar 2, 2008 | 08:41 PM
Franklin2's Avatar
Franklin2
I remember in my truck being able to see that wire hanging around in there when I took the radio out.
Old Mar 2, 2008 | 08:49 PM
ri_truck_guy
There are two places you can find the yellow/blue. Unless someone cut it up already and used it as the hot feed for your Alpine, it'll be tucked in the lower part of the dash just to the left of the lighter location....it was a standard part of all the wiring harneses back then. The other place you'll find it is in a plug that terminates in the same general area. This is the constant hot in the harness for the clock, which was a plug and play option. In other words, if your truck has a clock, the plug will be connected to a small harnes going to the clock. If your truck didn't have a clock, the plug will be there but not connected to anything. Either way there will be a hot yellow/blue wire.
Old Mar 2, 2008 | 09:19 PM
86F150302's Avatar
86F150302
all right. I looked to the left up under it and kept looking then I saw it. It another wire that was twisted into it that was just sitting there so I connected the Yellow/Blue into my wire going to the lighter and grounded the other one and it works!
Thanks alot everyone!
