Sponsored by: Auxito
missing
Old Mar 2, 2008 | 04:25 PM
th_72949's Avatar
th_72949
missing
i have a 2002 ford 150 with a 5.4L. it misses sometimes and some times it dont. it might go a week and not miss. then it might miss for the next two days. but only some of the time. it doesnot matter if it is under a load or not.
Old Mar 2, 2008 | 06:42 PM
Dustin1690's Avatar
Dustin1690
Welcome to the site try pulling the codes by hooking it up to those code readers i always hear autozone does it for free maybe a tune up is in order
Old Mar 3, 2008 | 04:26 AM
th_72949's Avatar
th_72949
i have done a tune up. put it on a scanner. it didn't pull up and codes.
Old Mar 3, 2008 | 03:12 PM
JOE SKI's Avatar
JOE SKI
if you changed athe plugs & wires then it's probably the coil- I just replaced mine which was doing the same thing & it runs good now.
Old Mar 3, 2008 | 06:45 PM
th_72949's Avatar
th_72949
my coils are over my plugs. i have 8 coils. so its kinda hard to find out witch on is missing. when it hardly ever does it at and idle.
Old Mar 3, 2008 | 09:43 PM
kingrancher1982's Avatar
kingrancher1982
if its a coil pack the check engine light will eventually come on. it may come on and then go off or maybe flash at first but the scanner wont pick up any codes until the light comes on and stays on. until then theres not much you can do but drive it as far as i know
Old Mar 14, 2008 | 04:15 PM
ferrisdeployed's Avatar
ferrisdeployed
I have a 99 Expo that does this same exact thing, however the "Engine" light comes on and stays until I reset the codes. Also, I have heard that if the engine doesn't do the same thing after like ten starts the light goes out, though this never happens until I reset it. I have changed two of the eight coil packs in three years and think I have another going again. Does anyone know if the earlier 5.4L Tritons have a problem tossing coils every so often?
