Cold no start
Old Mar 2, 2008 | 04:16 PM
brickie's Avatar
brickie
Thanks Jason.I am on the other computer reading the ICP tests right now.I can't seem to access the wiring diagram in the cd manual though. Thanks again for your help.
Old Mar 2, 2008 | 04:34 PM
04Xcursion's Avatar
04Xcursion
The ICP connector is 3 pins, A, B, C. Looking at the connector the 2 pins in the same orientation are A and B, C is oriented 90 degrees to the other 2. Pin A is pin 25 on the PCM engine harness connector, pin B is pin 36 and pin C is pin 29.
Old Mar 2, 2008 | 04:42 PM
brickie's Avatar
brickie
A-B shows 115 ohms resistance on the connector.I cant get the diagram to come up.Do you have a link that will show me the PCM harness connectors?
Old Mar 2, 2008 | 04:45 PM
brickie's Avatar
brickie
Found it ! Thanks again.
Old Mar 2, 2008 | 04:46 PM
04Xcursion's Avatar
04Xcursion
Excellent. I was still hunting.
No worries I hope you get this sorted out.
Old Mar 2, 2008 | 06:52 PM
brickie's Avatar
brickie
I am looking for the current path for pin 29 on the other side of the PCM.I have it traced it to a ten pin connector. Does anyone know the location of that connector?X I owe you a beer or two.lol
Old Mar 2, 2008 | 07:02 PM
04Xcursion's Avatar
04Xcursion
If you're looking for the path for pin 29 what did you find?
Do you have an open condition between pin C and pin 29 or do you have a low voltage condition on the ICP PID when pins B and C are jumpered?
From what I am seeing on my diagrams pin 29 terminates in the PCM, maybe I'm incorrect though.
Old Mar 2, 2008 | 07:11 PM
brickie's Avatar
brickie
Pin 29 is showing .003 with ignition on. Its way out .2 is what I am looking for.I had the drink I needed when I saw that.
Old Mar 2, 2008 | 07:16 PM
brickie's Avatar
brickie
X I was looking for the connector on the other side. It is out of the PCM into a 10 pin that uses 7 of ten on one side,three(I think) on the other.
Old Mar 2, 2008 | 07:36 PM
04Xcursion's Avatar
04Xcursion
Just so I'm sure of what you're doing, because you're pinpoint tests seem to be a little different than the one's I'm looking at, are you checking the voltage on pin C with the ignition on?
Did you check the resistance between pin 29 and pin C with the PCM connector diconnected?
The 0.003 and 0.2 you referred to, are those resistance values or voltage values?
Old Mar 2, 2008 | 07:47 PM
brickie's Avatar
brickie
Yes. the wire from the ICP to the PCM is good,no resistance.It isn't getting signal on PCM side. The connector I am after has Map,Maf & Iap it looks like a couple of grounds and a bunch of other stuff on the connector.
Old Mar 2, 2008 | 09:00 PM
04Xcursion's Avatar
04Xcursion
Sorry, I had to go forage for food
Do your diagrams give connector numbers? On mine I think the connector you're looking for is C1444. Which according to my manual is a 16 pin connector located in the left hand rear of the engine compartment underneath the auxiliary relays. the should be a bundle of 5 connectors there, C1444 should be the middle one. If you follow the wire for the air filter minder you sould be able to find the 5 connectors.
Just for reference it should have the following wires on it:
pin wire color
(1) 3073 (RD/WH)
(2) 3072 (PK/YE)
(3) 3091 (LB/BK)
(4) 351 (BN/WH)
(5) 356 (DB/LG)
(6) --
(7) 5 (OG/LB)
(8) 911 (DG/LG)
(9) 9 (DG/YE)
(10) 142 (LB/RD)
(11) 133 (BK)
(12) --
(13) 787 (PK/BK)
(14) --
(15) 3076 (YE)
(16) --
I think it's wires 351 and 356 that you are looking for.
Hope this is clear as mud.....
Old Mar 2, 2008 | 09:50 PM
  #28
04Xcursion's Avatar
04Xcursion
Little bit of extra info, looks like the VREF from the PCM (wire 351) comes from a least 2 pins on the PCM pins 36 and 45. If you're not getting any signal voltage I think you're going to need another drink because the PCM is likely a boat anchor.....
I hope you find something disconnected.
Old Mar 2, 2008 | 10:14 PM
  #29
brickie's Avatar
brickie
BINGO.X all I want is this sorted.I took time off work for the first time in 4 yrs to learn all I can on this motor.Man am I getting a lesson.PS The wife it seems for some reason still appears to love me...though I haven't seen her in a couple weeks.lol
Old Mar 2, 2008 | 11:04 PM
  #30
brickie's Avatar
brickie
I hope I have the problem narrowed down(thanks to a little help from my friends)to the ten pin connector that has 3 logic 2 voltage 2 ground.It comes out of the PCM but where does it go.#37 -29- 20- 25- Any Idea where these go into the harness.
