startup knock
Old Mar 2, 2008 | 02:04 AM
'86_150's Avatar
'86_150
startup knock
ok just yesterday my truck developed a knock. it only happens at startup for about 5 seconds then stops what could that be? thanks
Old Mar 2, 2008 | 04:55 AM
ozstang65's Avatar
ozstang65
Hydraulic lifter before it pumps up
Old Mar 2, 2008 | 06:04 AM
srercrcr's Avatar
srercrcr
I wouldn't characterize lifters as a knock, more of a loud clicking.
A knock could be engine bearings or perhaps piston pin. Try a lighter weight of oil, it should increase the flow a little, a needy bearing might appreciate it.
Old Mar 2, 2008 | 01:08 PM
'86_150's Avatar
'86_150
im running 10-40 so do think 5-30 would work?
Old Mar 2, 2008 | 01:43 PM
mhg's Avatar
mhg
what kind of oil filter are you using
frams are known for this
Old Mar 2, 2008 | 04:41 PM
srercrcr's Avatar
srercrcr
5 30 would be fine, especially at your latitude.
Old Mar 2, 2008 | 04:45 PM
Franklin2's Avatar
Franklin2
I would also change the oil filter. The anti-drain back valve inside may be leaking.
Old Mar 3, 2008 | 01:09 AM
'86_150's Avatar
'86_150
im using a k&n oil filter.. but yea ok ill change it when i get paid wednesday thanks for the advice
Old Mar 3, 2008 | 07:30 AM
F3Beam's Avatar
F3Beam
I had a "Knock" on startup with my F100 one time. I do think it lasted a little more than 5 seconds though, increasing the rev increased the speed of the knock, and then it would go away. It was the main bearings.
Old Mar 3, 2008 | 08:42 AM
ri_truck_guy's Avatar
ri_truck_guy
I had a similar problem with one of my old 300s. I kep the same weight oil, but switched to a synthetic blend. The knock went away and never came back.
Old Mar 3, 2008 | 09:14 AM
GLR's Avatar
GLR
Sounds like the engine is getting tired. I went to 20-50 a couple of years ago in my 351 it made a big difference.
