Cam Info
Old Apr 24, 2002 | 11:02 PM
adobbs's Avatar
adobbs
Cam Info
Hello need a little info have a stock 351m in a 1077 F150 2wd just doing a overhul have a new cam the spec are intake duration@.50 is 204 Exhaust duration @ .50 is 204 Intake lift .484 Exhaust life is .520 intake center line is 107 Hydraulic made by Manley can find no wher that it tells me if it has to have diff valve springs.Just don't want to put every thing together and turn it over by hand to see and then have to pull the heads and change springs and waste head gaskets every thing is stock any info will help thank you
Old Apr 25, 2002 | 02:50 AM
Superdave's Avatar
Superdave
Cam Info
Try and contact the cam maker if possible.
Old Apr 25, 2002 | 12:37 PM
Fastcat's Avatar
Fastcat
Cam Info
