I wish i had a quick answer for you. However, if you take that pic into a Ford dealer's part dept they will be able to bring up a diagram of the part and find it for you.
thanks Tim, hopefully someone else will know i dont have a printer. i have tried searching online for a diagram, and havnt found one. i also tried some junkyards but they didnt have it either. i would think its something i could get at napa since it wears over time im sure other people have replaced it.
That's a rag joint. I saw one in the "help" section of advance, or autozone the other day.
Go to a junk yard and find a F series with the U-joint instead of rag joint. Or get the hole saw and old tires out and make your own. I've done that for a couple of IH cub hydros I have. It's good enough for 3600rpm, good enough for that.
EDIT: double them up using longer carriage bolts if you can. Thats how I do my rag joints on the cubs. Also use flaired lock nuts with flange.(not nylon, but punch set type like found on the F series.) Don't over tighen that you imprint the rubber too much. Just good N' snug.
