Feeding a 410
Feeding a 410
Looking for opinions on what carb size to use on a 66 410.
Just found credible evidence that the stock carb (Autolite 4100-A stamped 1.08) was a 480cfm. I have that carb but after going through it three times with my uncle who's made his living as a mechanic for more than 50yrs we just can't get it running right.
I've got a Holley 4160 (600 cfm) I tried on it and wasn't altogether impressed.
Now I've got a Demon Jr 725cfm that I'm trying out. I was long under the impression that the original carb was a 650cfm, but my recent discovery that it's likely 480cfm has me questioning things. Many people, knowledgable folk said 650 was on the restrictive side for a 410cid.
Wonderin' what y'all think.
BTW--This build is for highway driving and some grocery running, NOT racing. Thanks.
Originally Posted by Ford428CJ
Run your Autolite! Or run what you have. You pretty much answered your own Q LOL....
And I can't run the Autolite...or rather, IT won't run. Hence the need for something else, but WHAT something? Is 725 too big? I'm sure it wouldn't be if everything else were tuned for the drag strip, but I'm building this for highway cruising.
Originally Posted by Blue50F-1
Ever heard of Hermiston, OR?
That 725 is not to big! Run it and you will find that it will be just fine. Even on mileage! You'll have the get up and go too. Thats only if you need it LOL. Just tune it in and "GO" LOL.
Thanks. I'm fighting the 725 right now. Having trouble getting it dialed in. Yesterday it ran fine. Today it wants a real high idle or it will die when I put it in gear, and it's pulsing cruising around town. It was running too rich. Doesn't seem to be now, but might be too lean? Anyway...when I heard the original carb is 480 cfm I thought I might have WAY overshot with my carb and be drowning my intake.
Off topic: I grew up in Hermiston. Know exactly where Klamath is, though Grants Pass and Bend & Redmond are the closest I've been. Love that country.
Royal--
Vacuum leak wouldn't be a surprise, but starter fluid takes even less to bog the engine down. It just flat won't rev...carb cleaner or starter fluid (ether based btw). Spray too much and the engine bogs, spray any less and no effect. It has me stumped that's for sure.
I may try plugging every vacuum port in it (save for the tranny, brake booster, and advance) and see if that doesn't change things. Though I know that a vac line may not be the source of the leak it's going to be hard to locate if it won't rev. Any ideas on locating a leak are very appreciated though!
A varying idle, etc could also be a symtom of a worn distributor bushing, and will dramatically vary points gap and dwell. Since you seem to be having issues with multiple carbs, maybe its not the carbs.
The 428CJ only ran a 735 Holley and turned 6,000 with it in stock form. So IMO a 752 is to big for a stock 410. Look here for Holley's remomendation on carb size. The first question answers your question.
http://www.holley.com/TechService/FA...ory=Carburetor
Originally Posted by 1Fordnatic
My 410 runs great with a 3 duece setup which comes out to around 1180 cfm! But of course it's a progressive linkage, so you get the best of both worlds-2bbl economy and 6bbl performance!! It took a lot of tuning, but there is no bog or anything when dropping the hammer.
I had to tweak the accel pumps (was getting too much, actually), main jets (I lived a mile high at the time), and linkage to get everything working right. Actually, Holleys aren't able to be adjusted for the thin air of high altitude very well, at least compared to the Carters and such that have the metering rods. My biggest problem was under heavy braking (like when the stop light turns yellow), the engine would flood and die. I discovered that since the carbs mount backwards (float bowl to rear) the fuel would slosh out of the float bowl through the vent right into the venturis. The fix was a "whistle" that in effect extended the vent opening to the rear of the float bowl. It was actually made for drag racers to put on the front float bowls for the same flooding problem on hard leaves.
