What Transmission
Old Mar 1, 2008 | 08:31 AM
rmalottwtes30's Avatar
rmalottwtes30
What Transmission
My truck is a 1985 f250 with a 6.9. When I went to get parts for it they asked if it was the c6 or the AOD. Heres the vin if that helps..
1FTHF2616FPA53623
Old Mar 1, 2008 | 09:21 AM
ctubutis's Avatar
ctubutis
Looking on the identification label on the driver's side door jamb will give codes as to what was installed as it came out of the factory, the VIN doesn't contain such information. Maybe somebody will be able to tell you how to ID the tranny by looking at it (number of bolts holding on the pan, for example) but I certainly don't know enuff about auto trannys to do that.
-ct
Old Mar 1, 2008 | 09:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1985 6.9 = C6 / No AOD's were ever installed in diesels (thank you lucky stars!)
1985/88 = C6's / 1989 and later = E4OD.
FYI
The trans code was never in a Ford's VIN.
Look on your Certification Label for the TRANS code. C6 = K.
C6 = 17 transmission pan bolt holes.
Old Mar 1, 2008 | 11:11 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Also on the cluster, does it have P-R-N-D-2-1?
Old Mar 1, 2008 | 12:52 PM
rmalottwtes30
Yes it does
Old Mar 1, 2008 | 03:23 PM
Archion's Avatar
Archion
Definatley not an overdrive (AOD) then. As posted above, you are looking at a C6 more than likely.
6t6merc
Oct 7, 2002 07:49 PM
6t6merc
Feb 13, 2002 03:20 PM
6t6merc
Dec 10, 2001 09:50 AM
6t6merc
Oct 24, 2001 07:46 PM
6t6merc
Oct 22, 2001 12:56 AM
