Gettin closure, CR guestimate??
Old Feb 29, 2008 | 11:53 PM
mustange70's Avatar
mustange70
Soooooo my 400 is just about done with, machinest is having to cut some valve reliefs in the pistons which leads me to the question of the hour . . . . . Anyone want to guestimate a cr ratio for me, 4v quench heads, pistons were custom ones to get the cr as high as possible, and upon final installation/checking the valve were found to be touching the pistons, the cam a comp cam 275deh (http://www.compcams.com/Technical/Se...umber=32-208-3), so with flat top pistons and closed chamber heads with the valves just touching (well enough clearence to run but not enough at 5000rpm for any extended period of time) what type of cr will i be looking at (block and heads haven't been milled), i'm hoping for 11:1, this going to be anywhere near.
Old Mar 1, 2008 | 05:54 AM
mustang81's Avatar
mustang81
http://raceabilene.com/kelly/hotrod/compression.html
