Found stroker kit, help me choose . . .
Old May 13, 2002 | 09:39 PM
mustange70's Avatar
mustange70
K everyone, I have finally found some stroker kits, and since I am young, I need some help on picking which one (I have very little experience in this area). I would also like some advice on a cam that would be good to use with the stroker kit of choice. This motor will get a mild head reworking, 4v intake and exhaust along with a 750holley double pumper.
Heres the list:
From D&D AUTOMOTIVE SPECIALTIES:
377CI-351C
Prepped offset ground (cast) crank, H beam connecting rods, custom forged pistons, rings, bearings & balancing
$2095.00
395CI-351C
Prepped/modified crank (cast/nodular), H beam rods, custom forged pistons, rings, bearings & balancing
$2545.
Or From Flatlander Racing:
Please use this color-coded chart as an easy reference to the listed assemblys.
1 SCAT 9000 Series Crank w/ 3.850 Stroke Crankshaft
2 SCAT 4340 "I" Beam Rod 6.00 Connecting Rod
3 SCAT/PRO-Line "H" Beam Rod 6.125 Connecting Rod
4 SCAT/PRO-Line "H" Beam Rod 6.200 Connecting Rod
5 Callies Forged Rod 6.00 Connecting Rod
6 Oliver Billet Rod 6.00-6.200 Connecting Rod
7 JE Forged F/T Piston Piston
Ford 351C Block/396 cu. in.
Pick a Crankshaft,Rod, and Piston combination from the menu below to match the stroker kit listed above.
All kits include Crankshafts, Rods, and Pistons.
Item # Block Crank Rod Piston Price
SKFC3961 351C 1 2 7 $1499
SKFC3962 351C 1 3 7 $1599
SKFC3963 351C 1 4 7 $1599
SKFC3964 351C 1 5 7 $1849
SKFC3965 351C 1 6 7 $2349
Or (From the same company)
1 SCAT 9000 Series Crank w/ 4.00 Stroke Crankshaft
4 Oliver Billet Rod 6.00-6.125 Connecting Rod
5 JE Forged F/T Piston Piston
Ford 351C Block/408 cu. in.
Requires Rollmaster Timing Chain & Motorsports Spacer M19009-A341 Pick a Crankshaft,Rod, and Piston combination from the menu below to match the stroker kit listed above. All kits include Crankshafts, Rods, and Pistons.
SKFC4081 351C 1 2 5 $1459
SKFC4082 351C 1 3 5 $1599
SKFC4083 351C 1 4 5 $1999
Thanks for any help you guys give me.
82' Flareside: zoom zoom doesn't even begin to describe it
2/4 Drop
Soon to have 325hp 351 Clevo
(maybe more,in a 3600lb truck)
Backed by a C6 with a 2000 rpm stall and a 3.50 9 incher
American Racing AR-23 (series 23) wheels
Upgraded interior
Soon to have a kick @$$ stereo
Old May 14, 2002 | 04:31 AM
GT40man's Avatar
GT40man
well id say go big, but thas just me.
Old May 14, 2002 | 07:17 AM
shazam's Avatar
shazam
If it was up to me this is the one I'd get.
395CI-351C
$2545.
Old May 14, 2002 | 09:11 PM
canadianfordman's Avatar
canadianfordman
