302 coolant leak
Old Feb 29, 2008 | 03:17 PM
operator exmark's Avatar
operator exmark
302 coolant leak
I have a '90 302 with 120k on it that empties its coolant resevoir after about a week. This has been going on for a few months and I recently noticed coolant on the drivers side cylinder head where it meets the intake manifold. Although the leak appears to be only up front I don't think it is the water pump because that was replaced 20k ago. There isn't any coolant flowing through the intake manifold is there? I'm assuming it is the head gasket but I could be wrong. Any opinoins?
Old Feb 29, 2008 | 03:35 PM
fmc400's Avatar
fmc400
MSEE
302 has a wet manifold; you will notice the upper radiator hose connects to the intake manifold on the front, which is where the thermostat sits. So yes, coolant flows through it.
Old Feb 29, 2008 | 03:51 PM
operator exmark
So does that mean it could be the manifold gasket? I can't think why else there would be coolant on the manifold.
Old Mar 1, 2008 | 12:11 PM
operator exmark
So before I go replace my intake manifold gasket a faulty gasket could cause coolant to pool around the distributer?
Old Mar 4, 2008 | 09:40 AM
cleeE150's Avatar
cleeE150
before doing manifold,gasket,ck all hoses, thero housing,for leaks. thottle body,coolant leaks.........etc. some are very hard to see. hope this helps.........
ForKyleigh
Modular V10 (6.8l)
Oct 25, 2019 08:53 PM
msalvetti
3.8 & 4.2L V6
Jun 5, 2016 09:12 AM
mgregoris
Modular V8 (4.6L, 5.4L)
Jul 14, 2015 08:23 AM
Bob_Cook101
2004 - 2008 F150
Feb 12, 2014 08:03 PM
