Crane Cam Advice
Old May 8, 2002 | 07:29 PM
335clevo's Avatar
335clevo
Crane Cam Advice
Hi All,
OK, I have just about completed my list of things I need for my 351C (I want to save up get everything, and put it all together in one go).
I need some advice on the cam, it's a CRANE CAM, No. R-246/3236-2-8, and the specs are below. I realise it will be pretty wild, but how much horsepower and how streetable will all this be? What kind of low end torque will I get? An could I safely do 7,000 rpm?
THE CAM:
Degrees Duration @ .050 Intake: 246, Exhaust: 256
Degrees Advertised Duration Intake: 284, Exhaust: 294
Degree Lobe Separation: 108
Open/Close @.050" Cam Lift Intake: 20 46, Exhaust: 61 15
Lash Hot Intake: .024, Exhaust:.026
Gross Lift Intake: .560, Exhaust: .585
This is what I want to put into it:
CLOSED CHAMBER 4V HEADS
ROLLER TIMING CHAIN
CRANE ROLLER LIFTERS
CHROME MOLLY POUSHRODS
CRANE ROLLER ROCKERS
TITANIUM VALVES (SINGLE GROOVE)
CRANE DUAL VALVE SPRINGS
CRANE TITANIUM VALVE SPRING RETAINERS
CAST ALLUMINIUM FLAT TOP PISTONS
CHROME MOLLY RINGS
MANLEY 8000RPM ALLUMINIUM RODS
STEEL CRANK
HIGH QUALITY BEARINGS
FELDPRO GASKET KIT
EDELBROCK TORQUER SINGLE PLAIN INTAKE MANIFOLD
780 CFM DOUBLE PUMPER HOLLEY (GTHO)
PHASE IV" EXTRACTORS.
DUAL 2 1/2" EXHAUST
ELECTRONIC IGINITION
COLD SPARK PLUGS
HIGH VOLUME WATER PUMP
ELECTRIC ENGINE COOLING FANS
3 CORE RADIATOR
'BAFFLED' SUMP (HIGH VOLUME OIL PAN)
OIL RESTRICTON KIT/HIGH VOLUME OIL PUMP
Old May 9, 2002 | 02:46 AM
xyfalcon500's Avatar
xyfalcon500
Crane Cam Advice
I am guessing that you are in Australia. Whereabouts? Need a set of pro-stock 4v's and matching Victor NASCAR manifold?
Old May 16, 2002 | 02:32 AM
xyfalcon500
Crane Cam Advice
Old May 19, 2002 | 06:46 AM
335clevo's Avatar
335clevo
Crane Cam Advice
Sorry mate but I already have the heads, but thanks anyway!!
I live in north Queensland.
335C
