Big score!! and one question
Old Feb 29, 2008 | 11:05 AM
killerkjn's Avatar
killerkjn
Went to the local pull-a-part and found a 64 ford f250. This truck had a mint core support, hood, inner fenders, 4 speed transmission cover and many small clips and *****. Got all this for 100$. MY question is the door tag shows an axle code of b6 it is a dana 60 rear end. Does anyone know what ratio this is. I'm at work now and don't have access to my shop manual. My friend also has a 64 f250 with a 4:56 rear end He's hopeing the b6 is a higher gear. Thanks
Old Feb 29, 2008 | 12:11 PM
BobbyFord's Avatar
BobbyFord
I don't see a B6, I see a B5 which is a 4:10
Old Feb 29, 2008 | 02:21 PM
airharley's Avatar
airharley
B6 is a Locking 1964 Dana/Spicer 60 with 4.88 gears. Section 40.1 page 2 of the master parts index catalog for 64-72 trucks. How that helps give your friend a big cheesy grin.
Old Mar 1, 2008 | 10:19 AM
BlueOvalBud's Avatar
BlueOvalBud
Locking differential? how does it work, is is a cable actuated locker?
Old Mar 2, 2008 | 04:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford calls it locking in the axle decode section of the parts catalog, but...it's really a clutch plate (6 lined, 4 steel) limited slip.
When 9's of this vintage have this same type of "locking" rear axle, they're called Equa-Lok's.
When I decode VIN's that have a locking rear axle, I refer to them as limited slip to end any confusion...before it starts...as in your case.
Old Mar 2, 2008 | 07:11 PM
BlueOvalBud
ohhh ok, thank you for helping end my confusion
slickrick85
Nov 7, 2016 12:32 AM
Hunter40
6.4L Power Stroke Diesel
50
Dec 18, 2015 02:30 PM
Jeff Watts
Sep 26, 2015 08:02 AM
supercub
Feb 5, 2001 09:05 PM
