WVO ideas and questions
Old 03-06-2008, 07:40 AM
dzzavid's Avatar
dzzavid
dzzavid is offline
ok, i was looking at this thread too https://www.ford-trucks.com/forums/6...?highlight=wvo
but any way i was thinking about setting up my truck to run on WVO. Here is my general idea. Please criticize if you see any problems with this.
1. i am going to modify my aluminum auxiliary tank 100gal (with baffles). I am going to put a small honda radiator in the tank for heat exchange, i will be using my main coolant line. this will heat the wvo to about 180 (will this be a problem?)
2 have a circulation pump (on a switch) to filter the wvo down to 5 microns.
3. Put a fuel selector before the factory fuel pump. so i can utilize the factory pump. Is the heat too high for the factory pump?
also i will be monitoring the temp with in cab temp gauges and controll the system by in cab switches.
any one have anything to add or criticize about this idea?
oh and i will be heating the WVO in the fuel lines by running the coolant line next to the fuel lines (will be wrapped with insulation) will this be a problem heating #2 to this temperature?
thanks for your help guys!
dave
Old 03-06-2008, 07:48 AM
dzzavid's Avatar
dzzavid
dzzavid is offline
also forgot to ask , do i have to worry about separating water?
Old 03-06-2008, 08:04 AM
dzzavid's Avatar
dzzavid
dzzavid is offline
oh, and for my collection i am going to retrofit a small 20-40gal super sucker (hopefully i can fit this under the truck bed)
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
parkland
08-26-2008 06:30 PM
Orpackrat
10-14-2006 12:03 AM
ToddT
05-15-2006 03:55 PM
parkland
17
03-27-2006 03:02 PM
Quick Reply: WVO ideas and questions
