Sponsored by: Auxito
ABS Light and Engine Stutter
Old Feb 28, 2008 | 09:23 PM
KevinT_87's Avatar
KevinT_87
Well my ABS light is coming on when I start my truck and it makes the engine stutter like it wants to die. But whenever I press the brake it quits. Does anybody know what could be causing this?
Old Feb 29, 2008 | 12:08 AM
Bluegrass 7's Avatar
Bluegrass 7
You need to get a dealer to read the failure codes associated with the brake system then go where the failure points according to the code discriptions.
I suspect the pump stops as soon as the control system detects the brake pedal off normal switch operation, suggesting possibly a control relay is stuck closed.
Normal code readers won't read these codes. Look for a Cxxxx type code.
Good luck.
