Sponsored by: Real Truck
A squeaking/scraping sound
Old Feb 28, 2008 | 06:41 PM
SC_Dave's Avatar
SC_Dave
I notice more when the weather is cold. This is the third Ford truck I have had and all had the same noise. It's in the front on the driver side. It can be heard mostly at low speed when hitting bump or hump. But, it is very noticeable when you go over a parking lot speed hump and slowly come off the other side and get a little bounce. It is a squeaking scraping sound that it very irritating.
Any ideas fellows?
David.
Old Feb 28, 2008 | 07:21 PM
skoveng's Avatar
skoveng
My '03 makes the same squeaking sound doing the same traffic bump bounce at slow speed. I thought it was the spring leafs rubbing each other. I lifted the truck by the frame which caused the leafs to seperate enough to get some grease in between them and WD-40'd the bushings. It seamed to work for a while but the squeak returned. I recently put a 4" lift on it, new springs with bushings and new sway bar bushings; the squaking is still there. The only thing I can believe it is now would be the upper rear hanger bushings; othe only bushings that weren't replaced.
Old Feb 28, 2008 | 07:25 PM
ford_boy_1996's Avatar
ford_boy_1996
Wink
Try your ball joints you might need to grease them I've see it before
Old Feb 28, 2008 | 07:29 PM
skoveng's Avatar
skoveng
Yes, it could be. But for me I had to replace the right side 10K ago and the left side 4K ago.
Old Feb 28, 2008 | 07:39 PM
SC_Dave's Avatar
SC_Dave
Had them replaced already and the noise is still there, so I don't know......
Old Feb 28, 2008 | 07:50 PM
ford_boy_1996
Lube up all the moving parts in your front end with PB blaster or something and see if it goes away. you might wonna try them one at a tome so you will know witch one is doing it.
