Sponsored by: Real Truck
6 liter with problems
Old Feb 28, 2008 | 10:46 AM
KEO's Avatar
KEO
Question 6 liter with problems
My 6 liter starts real hard even when it's not cold out. Replaced both batteries and still hard starting. Now it seems to have a miss at idle,and sometimes while driving it seems to sputter. Could this all be caused by the cam position sensor
(crank sensor)? I've had 7.3 liters do similar but the end result was they wouldn't start.
Old Feb 28, 2008 | 11:04 AM
TexMexF250's Avatar
TexMexF250
Pull the codes and see what it doing.
Old Feb 28, 2008 | 11:22 AM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Could be many things. As Tex said, pull the codes and go from there. The CPS hasn't been a major issue for the 6.0 as it has been for the 7.3.
Old Feb 28, 2008 | 03:11 PM
highland61's Avatar
highland61
Pop your egr out and see how it looks. You can clean it or replace it yourself. It could also be an injector or two. Next I would look at the wiring harness.
Pull codes first chance you get, would be worth investing in one if you haven't already.
