Solenoid switch
Old Feb 28, 2008 | 01:23 AM
mememe's Avatar
mememe
Solenoid switch
Hello have a 1989 F25O with towing package 5.8. in the last 3 years 3 times i have replaced the solenoid switch. each time its the same a few times of the starter running long and then not stopping till i get to the battery and disconect it. the last time i was a bit slow and by the time i got it off had burned out the starter. replaced it this was about 7 months ago.Today it started doing this again. going to just toss on a new solenoid switch in the morning but was wondering, Is this just a weak spot of the truck am i missing something or could something else be causing the solenoid switch to go bad ? thankyou
Old Feb 28, 2008 | 06:33 AM
Animalistic's Avatar
Animalistic
It sounds like your ignition switch is not switching out of "start" and is keeping power to the starter circut. I am not too sure on how to test it but my guess would be to remove the small wire from the solenoid and hook up a test light. Do a few "starts" with the key and see if the light turns off when you switch back to run. Hope this helps.
