Replaceing my front fuel pump?
Old Feb 27, 2008 | 08:50 PM
Handegard's Avatar
Handegard
I have a 1985 F250 2wd 460 standard cab.
I've got two tanks, both metal, and they're setup with a return system.
I'm trying to buy a fuel pump, but I don't know how to figure out which one I need. Best I understand, I have a 22g or 19g front tank, but I can't figure out which one.
Is this on a door code, or an easy way to tell?
Old Feb 28, 2008 | 07:39 AM
beetle's Avatar
beetle
19 gallons each.
Old Feb 28, 2008 | 11:58 AM
Handegard's Avatar
Handegard
Is there any chance of aftermarket or optional tanks?
I could have sworn I remember my fron tank holding north of 30 gallons when I used to drive the truck, and I've always thought my rear tank was about 10-12...
Old Feb 28, 2008 | 02:04 PM
Archion's Avatar
Archion
Veteran: Marine Corps
more info
Measure the length of the front tank, the only two options available for the front tank on a standard chassis were 16 and 19 gallon. The rear was a standard 19 gallon with an optional 38 gallon unit. Cab/Chassis vehicles may have had other options, but I have no listings on those. the 16 gallon measures 42 3/8" with the flange and the 19 gallon measures 58 7/8" with the flange. Your truck should have the 19 gallon front tank being standard cab F250 long box. I have Airtex#s for the pump assembly and the seperate components as well. As Follows:
COMPLETE UNIT W/ SENDER: E2138S
SEPERATE PUMP AND SOCK W/O SENDER OR BRACKET : PUMP = E2025 - SOCK = FS10
These numbers are the same for Master/Airtex, any major parts supplier should be able to work off that. My personal reccomendation would be the entire assembly, that way you dont have to worry about rusty components and the sender not working when you reinstall the setup.
Hope that helps ya.
Old Feb 28, 2008 | 03:44 PM
Handegard's Avatar
Handegard
Well, I'm gonna have to drop these tanks at work and see whats going on. I know my front tank is full, but with a bad pump, and I know I never got more than 10-11 gallons out of my rear, so I'll have to see if my rear tank has a broken pickup or something.
I know I need new senders. When my front tank said empty, that meant it had 10 gallons. When my rear tank said empty, it was DRY.
Old Feb 29, 2008 | 07:34 AM
Archion's Avatar
Archion
Ok I found some more info, There was a 22 gallon center tank, but it is such a rare option that I doubt you have to worry about it, looks like it may have been a cab/chassis tank. The Airtex/Master # for the rear 19 gallon sender assy. is E2128S if you need it.
Old Feb 29, 2008 | 08:55 AM
lsrx101's Avatar
lsrx101
[QUOTE=Handegard]Well, I'm gonna have to drop these tanks at work and see whats going on. I know my front tank is full, but with a bad pump, ... QUOTE]
With a full tank you might want to think about pulling the bed, not dropping the tank. That's about 150 lbs of liquid sloshing around. Pulling the bed makes fuel pump jobs much easier.
Old Feb 29, 2008 | 12:01 PM
baffledinpa's Avatar
baffledinpa
[QUOTE=lsrx101]
BTDT several times.
The way Ford setup most of their filler necks on the tanks, It is near impossible to get anything in there to siphon out the gas first.
Old Feb 29, 2008 | 06:47 PM
nsshull's Avatar
nsshull
Im doing that exact job right now. Be sure that if you order just a pump to get a new strainer! mine didnt tell me that in the online order place. But it's pretty easy if you can get the tank empty. Mine was half full, so slightly awkward. But overall not too bad. Same truck basically, but 2 years older.
Old Feb 29, 2008 | 07:09 PM
Handegard's Avatar
Handegard
Both my tanks are full, but that won't be a problem. We have a jack made for lowering gas tanks at work. It's pretty easy full or empty when you have a lift and a fuel tank jack
Old Feb 29, 2008 | 07:16 PM
nsshull's Avatar
nsshull
Do not forget a new strainer...and dont lose the lock ring....I hate living in the middle of no where No parts stores!
ri_truck_guy's Avatar
ri_truck_guy
Another big advantage of pulling the bed is you can run the truck and test everything to make sure its right before buttoning it up...don't have that option when dropping the tanks.
Old Feb 29, 2008 | 08:13 PM
baffledinpa
Full size fiberglass caps make that step of the process just a tad difficult.
Maybe Ford should design a bed system that folds up out of the way to get to these fuel pumps ??
Old Feb 29, 2008 | 08:21 PM
ri_truck_guy
Dewalt makes a pretty good sawzall.....
Old Feb 29, 2008 | 09:08 PM
Archion's Avatar
Archion
Spoken like a true Suffolkian...
Sorry I couldn't resist, I grew up in Newport News... Hung out in Suffolk a bit!
/Thread Hijack done
