6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Radiator Leaking Question
Old Feb 27, 2008 | 09:48 AM
jshumadine's Avatar
jshumadine
For the few of you mainly with Job 1's that have had bad radiators that leak, can you let me know how you found the problem? Was it a significant leak where you could see a puddle on the ground? Was it coming from where the rubber lines attach to the radiator or a hole in the radiator? I have a job 1 with only 1300 trouble free miles so far and I just want to make sure I know what to expect or what to look for should I have a problem which I don't anticipate.
Thanks
Old Feb 27, 2008 | 10:09 AM
CAxe's Avatar
CAxe
Puddle on the floor. Some days it was one or two drops and other days it would be maybe a cup or so. Problem was with the crimping of the radiator and not the rubber lines. Had it fixed in December and have not had any other problems with the truck.
Old Feb 27, 2008 | 10:28 AM
Leonandlisa's Avatar
Leonandlisa
I also noticed it by a few spots on the ground and it was dripping off of the front frame on the drivers side. My dealer replaced the radiator and I have been good since. I took about 5,000 miles on my truck before it started leaking.
Leon
Old Feb 27, 2008 | 12:56 PM
1968gtcs's Avatar
1968gtcs
The water was leaking on the Drivers side of the truck down the side of the radiator. As CAxe pointed out, it was a crimping issue on the side of the tank. My guages did not show any signs of the radiator being empty, so what your over flow tank.
Mine went out at 15K a couple of months ago, then again at 20K a couple of weeks ago. I'm on my third radiator.
Old Feb 27, 2008 | 01:04 PM
f350_canuck's Avatar
f350_canuck
My rad blew out pulling the 5er to Jasper in the middle of no where. Fun, fun, fun.
Old Feb 27, 2008 | 02:56 PM
dertdrag's Avatar
dertdrag
Mine was lower passenger side very slow leak at first, just a drip here and there, was real busy so just kind of ignored it until I had time to get it in to the dealer.
Then it went all at once in a big way. If you see a drip or wet area get it in to the dealer asap.
Old Feb 28, 2008 | 09:39 PM
scsmith42's Avatar
scsmith42
I smelled the leak for a week before I noticed the drip. Drivers side, halfway down the side of the tank.
Old Feb 29, 2008 | 07:22 AM
kimminau2's Avatar
kimminau2
Mine was also a slow drip on the passenger side, it never showed any signs of overheating or anything.
Old Feb 29, 2008 | 11:22 AM
Ranger372's Avatar
Ranger372
I just discovered mine was leaking last night. It is a few drops on the driveway and coming from the drivers side. I have 6113 miles on my F-250 SD 4x4.. Guess I need to take it in Monday morning..
Old Oct 12, 2008 | 03:00 PM
Champ198's Avatar
Champ198
Another leak
I have a job #1 truck. Got 25k miles on it. I was under the truck a little while ago to see how to adjust the angle of the fog lights and found evidence of a radiator leak. There was a drop forming on the bottom edge of the radiator on the driver's side. It appears to have been leaking for a while as there is drainage residue on the frame and on the radiator itself. I wondered why I had to add fluid to the coolant tank but didn't see any problems like puddles on the drive way, etc. . . . .
Old Oct 12, 2008 | 05:03 PM
Carl Lassiter's Avatar
Carl Lassiter
Sure it wasn't from the a/c unit? Hope so but if not get it warrantied and fit the venturi tee kit
Old Oct 13, 2008 | 02:21 PM
Champ198's Avatar
Champ198
Radiator replaced.
Dealership replaced the radiator today. (rather quickly) Service writer told me they stock the replacement units as this was a common problem on the initial Job#1 trucks. Forgot to ask about the T-connector, but I'll take a look when I get there to pick it up.
Old Oct 14, 2008 | 10:15 PM
chenderson's Avatar
chenderson
I'am going in on the 15th for my 4th radiator.
the 1st at about 5,000mi, the 2nd at about 13,000mi,the 3rd at about 25,000, and my 4th will be at about 35,000mi. all 4 times it has leaked on the drivers side.
Old Oct 18, 2008 | 03:18 PM
chairman13's Avatar
chairman13
Mine was leaking on the passengers side, as here in europe I don't have ford warranty i just added stop leak and it stopped leaking, now i did 1500 miles with it and it's ok if i get any signs of radiator leak i will order a new one
Old Oct 18, 2008 | 04:39 PM
DieselWhisperer's Avatar
DieselWhisperer
Mine never did leave a puddle under the truck. I just noticed the heater stopped blowing hot air one night (happened last winter with 18,000 miles) and the only sign was low coolant of course and a white powder type residue on the top of the radiator on the driver side.
