Cab Swap standard to ext.
Old Feb 27, 2008 | 03:05 AM
levi18175's Avatar
levi18175
I just acquired a 77 highboy, but the cab is some iffy condition. The heater box has been ripped out, and the cab mounts are made out of road signs. But I just got my hands on a 78 extended cab. Mine being a standard cab, I am wondering what I could have to do to mount this cab to my frame.
Mine is a LWB incase you need to know.
Old Feb 27, 2008 | 03:40 AM
fdude64's Avatar
fdude64
dont think it will work. the super cab is longer unless you maybe switch to a short box
Old Feb 27, 2008 | 06:37 AM
highboy1975's Avatar
highboy1975
yea, youd have to shorten the bed or go with a flatbed, if you still have a bed. also, you would heve to relocate the pieces of the frame that the cab mounts to.
Old Feb 27, 2008 | 01:07 PM
shoot4fun's Avatar
shoot4fun
The cab swap'll be easy enough. Moving the rear cab mount member isn't difficult. Grind off the rivets. Move it. Drill new holes. Bolt it back on. Highboys had a different frame width @ rear didn't they?
Old Feb 27, 2008 | 05:49 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Yeah highboys have a different frame dimensions behind the cab. IIRC the rear cab mounts on a highboy are on the outside of the frame rails whereas the 78 and newer use the crossmember set up
Old Feb 28, 2008 | 03:05 AM
levi18175's Avatar
levi18175
The truck doesn't have a bed. I was planning on building a flatbed. thanks for the input.
