Will this ball joint tool work for me?
Old Feb 27, 2008 | 12:06 AM
whatdyisit's Avatar
whatdyisit
I need to change the ***** joints on my '94 F150 4x4 and I wanted to buy the press instead of renting it.
Does anybody know if this kit
Ball joint press link
will work for my application?
Thanks
Old Feb 27, 2008 | 12:11 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
That tool will work. It is a little expensive though, check out this one from Harbor Freight, it is less than half as expensive.
http://www.harborfreight.com/cpi/cta...emnumber=38335
Old Feb 27, 2008 | 12:14 AM
whatdyisit's Avatar
whatdyisit
Alright. Saving some money. Thank you.
Old Feb 27, 2008 | 08:54 AM
rainbowATF's Avatar
rainbowATF
ball joint tool
I buy alot of HF and am selective about purchases. I bought the ball joint press to remove ball joints from spindles on a 95 F150 2WD. On second ball joint I cracked the C-clamp in half. Money refunded by HF. My neighbor, a 38 yr employed Ford worker knocked ball joint out in a vise with a punch and hammer. The metal on the cracked C-clamp looked crystalline in nature. Maybe a bad one. I replaced it with 40 pc adapters kit from them for future work. Same kit from KD or OTC is more expensive; maybe for reason. Try to rent the tool; it was $98 at Advance, but you get it back on return.
My next job was bearings and hubs on a Honda. I bought the HF 20 ton hydraulic press and this cost 160 with sale and 15% off. This one job paid for the press versus using a machine shop. However you will also need a number of bearing removal adapters to accomplish something like this.
Old Feb 27, 2008 | 10:05 AM
1994 F250: 351, C6
I have one of the Harbor Freight ball joint presses and it has worked great for me. I have done u-joints and ball joints in both my 94 F250 and my wife's 91 Explorer with it and not had any problems. You must have got a bad one rainbowATF! I wonder if I got lucky with mine, or if you just got really unlucky?
Old Feb 27, 2008 | 11:42 AM
Oscar Meier's Avatar
Oscar Meier
I have a HF press and I bent the first one on my '86 2wd - went back and got another and have done my '96 2wd with no problems.
