What is the most radical cam you can put in a 2v clevo with a 4v 4 barrel intake and exhaust with a 750 holley double pumper? I have a couple in mind but i can't find the specss. Thanks for any help.
82' Flareside: zoom zoom doesn't even begin to describe it
2/4 Drop
Soon to have 325hp 351 Clevo
(maybe more,in a 3600lb truck)
Backed by a C6 with a 2000 rpm stall and a 3.50 9 incher
American Racing AR-23 (series 23) wheels
Upgraded interior
Soon to install: Sony Xplod stereo
I have a few of them on the shelf but there all rollers Cams. The most rad. one would be this Engle RJ-38 Has great sound and gobs of power. Then I have one of Clay Smiths special Grinds R-310-8-SB that give me a woody seating in the truck when it's running.But the best one I have on the shelve is a Comp. Cams FC 296-7/306-7 R7 Major Woody with this one too.
K thanks. I will try to find the 2 cams i am considering and post them here k.
Cody, Coutts Alberta
82' Flareside: zoom zoom doesn't even begin to describe it, 2/4 Drop, Soon to have 325hp 351 Clevo (maybe more,in a 3600lb truck)Backed by a C6 with a 2000 rpm stall and a 3.50 9 incher, American Racing AR-23 (series 23) wheels, Upgraded interior, Soon to install: Sony Xplod stereo
I hope the intake you mention is an aftermarket 4bbl intake for the 2V Cleveland heads. If you try and use the 4V Cleveland intake on a set of 2V heads, you'll wind up with a horrible port mismatch that will cause all kinds of flow problems.
