66 vin question
Old Feb 26, 2008 | 12:28 AM
kd5gmw's Avatar
kd5gmw
66 vin question
I can't find a sight to tell me the original make up of this truck. The fellow I bought it from thought it had a 400, but the firing order is not correct for M blocks. the only number I've found is F10AL844348. Any help would be great.
THANKS, KD5GMW
Old Feb 26, 2008 | 04:29 AM
jowilker's Avatar
jowilker
This site might be of some help http://home.earthlink.net/~threynold...specs6166.html
A 352 was the only V8 offered in 66, so if it has a 400 or any other V8, it was added later.
John
Old Feb 26, 2008 | 04:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
THANKS, KD5GMW
Welcome to FTE
400 = 8 valve cover bolts. No 400's in F100/350's till 1977.
"Original" make up: F10AL844348 = This is your VIN (Vehicle Identification Number), what the vehicle is registered with.
F10 = F100 2WD / A = 240 1V I-6 / L = Michigan Truck Assembly Plant / 844348 = 1966.
429/460 = 7 valve cover bolts.
302/351W = 6 valve cover bolts.
352/360/390 = 5 valve cover bolts.
Old Feb 26, 2008 | 04:43 AM
Canadiansailor's Avatar
Canadiansailor
NumberDummy STRIKES AGAIN!!!!!!!
Old Feb 26, 2008 | 03:19 PM
kd5gmw's Avatar
kd5gmw
thanks guy's. Numbers dummy you need to live in my neighborhood if you ever get bored. I have 2 of these 60's [65&66] so I'm sure I could pester you to death.
THANKS AGAIN
KD5GMW
