oiling the 351M beast
Old Jul 2, 2002 | 04:49 PM
joe btrucks's Avatar
joe btrucks
Hello, for my 1981 Ford Truck Bronco,with the 351M and only 44500 miles, what oil brand and viscosity you suggest?
Early i was using Mobil 20W50 mineral oil with very good results,but it looks me some excesive viscosity for here (the oil pressure needle sits on top once you start the engine and stays always there until you turn off the engine).
Now, since here in Spain Mobil oil is not longer available, i put BP oil 0w30 fully sinthetic. Now the pressure needle lows a bit whe the engine catch normal operating temp, it always stays on the middle of the normal range or above.The operating temp looks a bit higher,but only a bit. With the Mobil 20W50 says always on the "N" or beneath "N" of "NORMAL" in the temp gauge, now with the BP sinthetic the needle reach "O" and even "R" of "NORMAL" .
What is your opinion?
Thanks!
Old Jul 3, 2002 | 09:36 AM
beartracks's Avatar
beartracks
I like synthetics but I also favor a heavy oil, especially in a hot climate. 15 or 20w50 syntec works well for me year round. It's thick enough to protect the engine in the summer and slick enough to flow good in cold weather.
For Dyno oils I prefer 10w40/20w50.
Bear Tracks
Old Jul 3, 2002 | 09:41 AM
beartracks's Avatar
beartracks
FarmLaw
20
Jul 27, 2017 10:40 AM
kincfu
Jan 31, 2016 05:56 AM
reamer
Apr 5, 2015 08:49 PM
Nathan Plemons
19
Dec 9, 2010 11:16 PM
