Stalling on initial start up
Old Feb 25, 2008 | 08:44 PM
fordboy67's Avatar
fordboy67
I have a 98 Expy with the 5.4l V-8. About a month ago it would not stay running when cold starting it in the morning unless I gave it a touch of gas, then it idled fine. I figured it was because of the extreme cold (it was -15 F). I changed the fuel filter since it looked original, or at least very used. This past week it has continued to do this even at temps at 10 to 20 F. I keep the gas at or above a half tank so I don't think freeze up is a concern. What could I check? Thanks in advance!
Old Feb 25, 2008 | 09:06 PM
tommyleea's Avatar
tommyleea
Do you have any codes? If not, I would probably start with the Throttle Air Bypass Valve.(common bad actor). Sounds like it might be sticking. You could try to just clean it to begin with.
Tommy
Old Feb 26, 2008 | 06:25 AM
fordboy67's Avatar
fordboy67
No codes, no check engine light, nothing. Runs fine after initial start up in morning.
Old Feb 26, 2008 | 05:45 PM
Modified 99's Avatar
Modified 99
It sounds like the Idle Air Control Valve. It can be cleaned or replaced. Removal is a PIA.
