Trucks and Rust
Old Feb 27, 2008 | 11:04 PM
Strife_17's Avatar
Strife_17
So would a drill motor w/ a wire brush, a few cans of Rustoleum Rust Restorer,
and soem oil based paint be the way to go? Just do the frame and any exposed metal of the underside of the cab? Should I prime over the rust retorer of use that as the primer/ base layer?
Thanks for all the help! I am so pumped to pick up my truck next week.
Old Feb 27, 2008 | 11:16 PM
BChance's Avatar
BChance
Give Eastwood Company a look, they have some outstanding stuff for rust now, and they are a site sponsor.
The Rust Encapsulator works WAY better than any others I've tried..cover with Chassis Black, it's durable, and looks great.
Old Feb 27, 2008 | 11:35 PM
ghunt's Avatar
ghunt
My truck was like that too.
Lots of rust on the frame and running gear, relatively little on the body (the previous owner had the rear wheel arches and one front fender patched at some point, whoever did it it did a pretty crappy job), although the mounts on the radiator support are completely gone.
Much of the underbody was pretty nasty.
I've gone over pretty much the whole frame and whatever else I could reach from the doors back with a wire wheel on an angle grinder, then sprayed it all with undercoating.
The truck's underside originally was undercoated, but it has fallen off/is falling off all over the place. I still have some parts of the frame to do when it gets nicer, and I'm replacing the front springs so I'm gonna clean up the whole front axle and all that.
The previous owner replaced the rear-rear spring hangers because they were completely shot even when I first looked at it, but the rear-front hangers also look like they need replaced. If only I could find the damn things for less than $55 each.
Still gotta replace the front fuel tank, which I have.
guessrow
Paint & Bodywork
Mar 25, 2012 05:09 AM
blackout150
Aug 13, 2008 10:57 PM
pipercub
Paint & Bodywork
Jul 2, 2004 10:23 AM
panteramatt
Mar 3, 2004 10:57 AM
