If you are in 4 LOW, you will need to stop the truck, put it in neutral and press on the brake. Turn the selector to 2wd while still holding down the brake, and wait for the xfer case to disengage. It may take a little time (up to 2 minutes). It will not change unless its stopped, in neutral with the brake applied.
i need your first name,im going to name my next child after you!!!!! male or female!!!!
lol
Cal Ntv,all fun'n aside,i really cant thank you enough,thats been weighing hard on me all day,like i said its been a really rough winter as far as work,and the pockets are thin and i really didnt need a monster repair bill
i bought the truck new,and keep the maintinance up on it and its never,and i mean never given me the least worry until this
thanks to you too Cal,it was in 4 low,i never use 4 low but just went too far when turning the switch and figured no problem and went on up the part of my drive where 4x is needed ,now that all the snow is melting its made a mess of things
ive had a knot in my belly the size of a basket ball all day
you guys are great,i had a feeling i came to the right place
My F250 4WD did the same thing on me a couple of weeks ago. I was on the way to my mechanic to see if he could get it out of 4WD. I was at a red light and for some reason put it in neutral and it just slipped back into 2WD. I was as relieved as you. It's been fine since then also. Glad I could help.
