confused about transmission. help!!
Old Feb 25, 2008 | 02:44 PM
jimbob21rc's Avatar
jimbob21rc
i talked to a transmission guy and told him about my problem with my trans.
the trans is not shifting out of 2nd at all but if i put in lo the engine revs high before it will take off then i can shift to 2nd and thats all i got he told me a few things to do to try to fix it 1 is to adjust the band, but anyway we were trying to figure out the trans type i told him it was a c4 case that is what it seems from the shape of the pan but he said that the rectangle filter was in a c5 but the auto parts said that they had 3 different filters for a c4 cause the 1st one they give me had several bolts where as the one i has only had 1 blot in the center and the trans guy said the c5 had a bad design and there was something can't remember what but something that would go out all the time so i was wanting to know what kind of trans i should put in here, i was going to get mine rebuilt but if indeed it is a c5 with a bad design then i want to go with something more reliable my truck is a 78 f100 with a 351w a/t, it came with a i6 and manual trans. which i would like to have the manual trans back on my 351 but have been told that it would be hard to find a manual that the bell housing would match up to
Old Feb 25, 2008 | 02:56 PM
MBBFord's Avatar
MBBFord
C5s were in Bronco IIs and maybe some Rangers.
C4s were behind 302s, and the 351W has the same bell pattern, so I'm sure it's a C4
The C4 also has the square/rectangular pan.
Old Feb 25, 2008 | 03:07 PM
masterbeavis's Avatar
masterbeavis
I had a difficult time reading that (no punctuation)
a c5 is a c4 with a locking torque converter. When they get rebuilt, they eliminate that portion of the c5 making it a c4.
the I6 and 351 share the same belhousing. Finding the small block belhousing is not impossible, just tougher.
