Sponsored by: Real Truck
Corroded cable
Old Feb 25, 2008 | 11:39 AM
Upnorthfro's Avatar
Upnorthfro
Corroded cable
I have a 2001 F250SD, 4wd, 5.4l. About every 12-15 months, the end of the battery cable to the starter solenoid corrodes and falls apart. This has happened since I bought the truck brand new back in '01. I also have an '02 Excursion with the same motor and this has never happened. Is there a way to keep this from happening again? Why doesn't my X have this happening? I drive both of them just about the same amount of miles every year.
Old Feb 25, 2008 | 11:51 AM
8tsixt's Avatar
8tsixt
Battery acid can run through the cable in any direction. More then likely your battery was seeping acid through the post.
Old Feb 25, 2008 | 11:54 AM
Upnorthfro's Avatar
Upnorthfro
Don't you think the battery would have gone bad by now? It's still the same battery that came in the truck.
Old Feb 25, 2008 | 07:41 PM
pbeering's Avatar
pbeering
Original battery? Replace battery; replace offending cable; liberally apply Fluid Film to the posts, contacts and so forth. Repeat periodically.
