C4 trans shifting odd....
Old Feb 25, 2008 | 10:44 AM
Mike G's Avatar
Mike G
This should be an easy one for the guru's.
Quick history - dropped the pan and put in a new filter, shifts good from 1-2 but 2-3 only occurs when I release the throttle, when I get back on the gas, it drops to second. Found a little fluid in the modulator so I bought a new one and did not cure my issue.
Thoughts?????
--Mike
Old Feb 25, 2008 | 08:04 PM
385seriesHemi's Avatar
385seriesHemi
I wanna say shift valve but the front band servo also come to mind.
Old Feb 26, 2008 | 05:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
i want to say the passing gear rod is stuck in pass.
i had the same problem on the C6 in my 79. when the linkage would dry out, it would stick in passing gear. spray it down with pb blaster every 6 months or so, and it has been fine for over 15 years now.
Mvidesco
Oct 11, 2014 08:40 AM
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
mike01082
Sep 20, 2010 09:36 PM
razormac
1983 - 2012 Ranger & B-Series
48
Apr 13, 2007 07:39 PM
mikew72
Oct 24, 2005 09:13 AM
